02-17-2022
11:42
15:45
DavideFitbit
02-17-2022
11:42
15:45
DavideFitbit
What happened? Charge 5 won’t sync for 2 days, all of sudden battery went from 98% to 1%. Not tracking anything.
Hi, welcome back to the Community forums, @Caroltav.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
Before considering other options, I recommend that you try restarting the device using the three pulse restart method described here below:
Keep in mind that you need to sync through the Fitbit app and not through the Bluetooth settings on your phone. In addition to the restart, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
Regarding the problem with the battery draining too fast, the restart should be of help as well, but make sure to follow the steps provided in this article as well to improve the battery life.
I'll be around.
Best AnswerOk, I reset the Charge, the App and my phones. I turned off Bluetooth, turned it back on and it synced for the first time in 2 days. Weird. Let’s see if it works all day today.
