05-25-2022
05:41
07:31
DavideFitbit
05-25-2022
05:41
07:31
DavideFitbit
The battery level indicator on the apps Home Screen has disappeared! It’s very hard to see on the device so I use the app to monitor. Since Charge 5 seems to use battery faster than 2,3,4 it’s important to be able to see it
Moderator edit: format
Hi, welcome to the Fitbit Community forums, @Uksausage.
I appreciate all the details that you've provided about this issue with the Fitbit app not showing you the battery indicator.
If you haven't done so already, please try the following steps:
Hope this helps, I'll be around.
