05-25-2022
06:14
07:37
DavideFitbit
05-25-2022
06:14
07:37
DavideFitbit
Sorry - now fixed! I just had to remove the device from the charger after following the steps below. Then it unfroze!
My screen is stuck on a screen which is showing battery power and the clock. I have tried to unfreeze it by pressing the small button on the flat end of the charger. After a few seconds the Fitbit logo comes up as if it has rebooted but then the same screen just appears again and I can’t swipe anyway to get off it.
Please help!
Hi, I appreciate all the information that you've provided about this issue with your Charge 5, @Kaz54.
It's good to know that your device started working again after you removed it from the charger and after the restart procedure. Thanks you for sharing this update!
See you around.
