Charge 5 won't sync properly anymore
ANSWERED
The app doesn't download info correctly. I have unpaired the devices and repaired. Info gets partialy uploaded en then stops for the last 3 days. This has never happened.
1 BEST ANSWER
Accepted Solutions
Hi there, @Karla2. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge is still not syncing. I understand your concern as this hasn't happened before, I will do my best to help you with this!
In order to avoid the hassle of providing the same steps you might have already done, please confirm that you've exhausted all troubleshooting steps provide here Why won't my Fitbit device sync?
If you've tried the above but to no avail,
please try the steps below in the order listed. Important: Please be aware that most Fitbit devices store up to 7 days of detailed minute-by-minute data. If you wait longer than 7 days before syncing, you may only see the most recent week's detailed data. Summary data (calories, distance, steps, and floors) will be stored for 30 days.
  • Unpair your Fitbit device from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Fitbit device.
  • If there is no connection, restart your Fitbit device.
  • Once your Fitbit device is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
1 REPLY 1
