05-10-2023
08:11
08:29
05-10-2023
08:11
08:29
Anyone else having issues getting their Fit Bit to synch today? I've tried all the usual fixes. Thanks.
Hi there, @Clahmani. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Charge 5 before reaching out.
In addition to the steps you've done, please try the following in the order listed:
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best AnswerIv still got problems today syncing my Fitbit 5 Iv done everything that has been mentioned but to no avail !!
Hi there, @Area51Sid. Welcome on board. Thanks for following the tips and recommendations I've provided above.
To better assist you, may I know the model of the phone you're syncing with? Are you getting any error message in the Fitbit app? In the meantime, please confirm that you've also tried all troubleshooting steps provided here Why won't my Fitbit device sync?
@Area51Sid I'm glad to hear your Charge 5 is syncing now. We‘re taking your comments and sentiments in regards to our products into consideration.
Regarding your sleep data, the sleep times might have been due to the syncing issue you were experiencing. With that being said, I'd recommend to sync your Charge 5 to the app after waking up. This will help to make sure that all your data is sync properly.
Also, note that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min.
To learn more about your time asleep in sleep stages, see What should I know about Fitbit sleep stages?
Edit or delete sleep logs in the Fitbit app. For instructions, see How do I add, edit, or delete Fitbit data and activities?
