05-23-2023
17:36
04:31
DavideFitbit
05-23-2023
17:36
04:31
DavideFitbit
My Charge 5 won't sync with my phone. Time is incorrect.
Moderator edit: format
Hi, it's good to see you visiting the Fitbit Community for the first time, @Heavychevy.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
Before considering other options, please make sure your phone meets the requirements listed here. Keep in mind that your Charge 5 may show an incorrect time if it hasn't synced or if it has been unpaired from your Fitbit account. Your Fitbit grabs the time of the device you're using to sync your data. If you haven't done so already, please try removing the Bluetooth connection between your phone and your Fitbit device:
Sync your Charge 5 automatically when you open the Fitbit app or manually by tapping your profile picture > your device tile > Sync Now. If the issue persists, please see Why won't my Fitbit device sync?
In addition, I recommend that you try restarting the device using the three pulse restart method:
