10-17-2023 12:30
10-17-2023 12:30
My Fitbit Charge 5 had plenty of battery, but just randomly switched off. It has been on the charger over an hour but still not switched on and is not connected to the app. I have tried doing restarts as described by pressing the button on the charger 3 times for 1 second in 8 seconds, or for 15 seconds then unplugging and back on and no luck. Any advice please?
10-17-2023 17:16
10-17-2023 17:16
Something strange going on…youre the 5th person who I see here, that this has happened to. Mine has done same thing in past 2 days.
10-17-2023 17:53
10-17-2023 17:53
I am having the exact same issue. I know the display works because the logo pops up and it even vibrates but then it seems to shut down. Has anyone found a solution?
10-17-2023 18:04
10-17-2023 18:04
Same symptoms here. No solution.
10-25-2023 00:48
10-25-2023 00:48
I'm having the same problem. Did you resolve your problem? If so how?
10-25-2023 04:14
10-25-2023 04:14
10-25-2023 04:18
10-25-2023 04:18
10-25-2023 07:26
10-25-2023 07:26
10-25-2023 07:34
10-25-2023 07:34
10-25-2023 07:59
10-25-2023 07:59
10-25-2023 09:04
10-25-2023 09:04
10-25-2023 10:12
10-25-2023 10:12
I'm running 57.20001.188.58 mine died last night can't get it going again. Tried the reset, cleaning the charger contacts, nothing works.
10-25-2023 10:15
10-25-2023 10:15
10-25-2023 11:21
10-25-2023 11:21
10-25-2023 12:01
10-25-2023 12:01
10-25-2023 19:24
10-25-2023 19:24
Isn't it!! Especially with the launch of the new charge 6!!
11-03-2023 07:15
11-03-2023 07:15
Me too! It happened so suddenly, I wish it wasn't bricked 😞
