10-10-2022 21:05
10-10-2022 21:05
Charger 5 purchased on 09/05/2022 stopped recording step data
Best Answer10-12-2022 08:04
10-12-2022 08:04
Hi, welcome to the Community forums, @Keith07.
I appreciate all the information provided about this issue you're experiencing with your Charge 5.
Let me know if your device is not tracking steps at all or if you're getting steps, but they're not accurate. In the meantime, please make sure that you've tried the restart procedure as described here below:
Then check if you continue to experience the same behavior. In the meantime, you can find more useful information about the accuracy of Fitbit devices and how to adjust your stride length and dominant hand settings here, as these settings are usually helpful to improve accuracy as well.
Hope this helos, I'll be around.
