03-13-2023
09:40
11:15
03-13-2023
09:40
11:15
Purchased Charger 5 second hand, had it charging for over an hour no sign of life
any advise other than the bin
Best Answer03-13-2023 11:16 - edited 06-03-2023 11:26
Hi there, @Petero1. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Charge 5.
If you haven't done so yet, please see Why isn't my Fitbit device's battery charging?
03-14-2023 01:55
03-14-2023 01:55
Tried all the troubleshooting suggestions but nothing is working, when connecting the devise to charge it vibrates
but nothing happens screen blank
Best Answer03-14-2023 03:49
03-14-2023 03:49
Sad to hear that you're having issues with your Charge 5, @Petero1. If you've not already done, I'd suggest to try restarting your device. To do so please perform these steps:
1.) Connect your Charge 5 to the charging cable which has to be connected to a power source.
2.) Press the button located on the USB plug of the charger 3 times within 8 seconds, holding each press for about 1 second(!).
3.) Wait 10 seconds or until the Fitbit logo appears.
If this doesn't work for you I'd suggest contacting Fitbit support to get further assistance as there might be hardware issues with your device:
Best Answer03-14-2023 04:34
03-14-2023 04:34
Hi Talahthas
Thank you for the reply can confirm tried all the suggestions unfortunatley all I have is a vibration
when attaching the charging cable but still blank screen.
