01-31-2022 08:08
01-31-2022 08:08
Are there clock faces available for the fitbit charge 5?
01-31-2022 08:30 - edited 01-31-2022 08:31
Hello @Poppy2013
There are quite a few available. If you go from the Today Screen in the App on your phone, tap your profile picture then Charge 5, then Gallery and Clock Faces,you will be able to see them all.
You can tap on them to see screenshots and more information. If you would like to change yours, choose one, tap Install and then sync your Charge 5.
I hope that helps a bit.
01-31-2022 08:53
01-31-2022 08:53
