04-13-2023
19:13
07:57
DavideFitbit
04-13-2023
19:13
07:57
DavideFitbit
My partner has a Charge 5 which she uses to track her walks. When she changed to a metal band, the built-in GPS no longer connects adequately (we've tried it both with and without the band). So it seems the answer is either to junk the band or use the 'connected' GPS mode with her Android cellphone (and I suspect she won't junk the band!)..
What concerns me is that she uses a separate tablet to sync the app to her Fitbit and download her walk data. So I have a few questions:
07:56
08:18
04-14-2023
07:56
08:18
Hi, it's good to see you around the community forums for the first time, @Gabbee.
I appreciate the information provided about the Charge 5 and the GPS feature.
When it comes to GPS, you have a few options with the Charge 5:
All devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. In particular, please make sure of the following:
If you continue to experience the same behavior and your GPS is getting disconnected, make sure to try following the steps listed in this article to complete a restart, as this has been useful for other users experiencing something similar. Regarding your questions:
1. You can sync your device with any compatible phone or tablet and use the connected GPS as well.
2. You don't have to sync constantly during your workout, but you can keep Bluetooth turned On so the device can communicate with the phone.
3. Wi-Fi is not specifically required, but to use connected or phone GPS, make sure that Allow Location Access is set to Always or All the time for the Fitbit app on your phone.
04-17-2023 00:08
04-17-2023 00:08
I tried this (noting that I have a nylon band). Generally it was unreliable, with the GPS cutting out far more easily than when using the Built-In setting. It also made it more difficult to sync on my tablet (I never got it to work reliably). So I wouldn't consider using it for myself.
So I'm giving up on the idea. My partner insists on her metal wristband and is reasonably happy to work with an occasional map and otherwise step-based distance figures.
09:48
06:51
04-20-2023
09:48
06:51
@Gabbee Thank you for taking the time to share your feedback and experience with the Charge 5
Please know that our team is always working to enhance your experience and your feedback is an important part of that process. This helps a lot to continue working on improvements to products and services.
