11-24-2021 12:28
11-24-2021 12:28
Apparently there's no built-in way to connect Fitbit to Apple Health? You have to use a 3rd party app? Any comments on which is the best app? Why doesn't Fitbit play with Apple? I understand they are competitors, but I don't think it somehow helps Fitbit sales to not enable this connection.
Best Answer11-24-2021 19:03
11-24-2021 23:45
11-24-2021 23:45
@Rich_Laue Likewise Fitbit has decided not to connect to Apple health.
11-25-2021 10:45
11-25-2021 10:45
I saw some apps listed, was wondering if anyone had a recommendation as to which to use.
Best Answer11-25-2021 10:47
11-25-2021 10:47
I'm pretty sure the issue is Fitbit - Apple has APIs for Health available to developers. Fitbit is choosing not to use them.
11-25-2021 16:37
11-25-2021 16:37
Fitbit has been very clear since long ago that they are not supporting connection to Apple Health (or even Google Fit when Google is the owner of Fitbit) because not convenient for their business model.
Best Answer11-25-2021 19:14 - edited 11-25-2021 19:16
In general fitbit will not force them self on to third parties, IE: Use their API without being asked, but invites third parties to work with fitbit.
There are two third parties that fitbit owns the APIs one of the came to fitbit and helped fitbit set it up so that your heart rate will sync, IFTTT is the other app.
@Barry07 Sync Solver is the app everyone points to. I can't find it anymore.
11-25-2021 19:42
11-25-2021 19:42
"There are two third parties that fitbit owns the APIs one of the came to fitbit and helped fitbit set it up so that your heart rate will sync, IFTTT is the other app. "
Sorry but I have big problems to understand you
Best Answer11-25-2021 19:46 - edited 11-25-2021 19:47
I found this excellent post explaining the point.
@Barry07 Check Power Sync that seems working very well judging by the votes
11-26-2021 11:49
11-26-2021 11:49
Best Answer01-23-2023 22:45
01-23-2023 22:45
To be honest, I had a cheap tracker watch I did calls and it cost me $25 text messages. It was way more informed than this Fitbit and it worked with my Apple phone and you can’t believe how much I am kicking myself in the butt for getting rid of that thing when I go in to Apple help it says you’re getting data from here in here and there’s no data from fit better all these stupid sync apps none of that works
Best Answer01-23-2023 22:47
01-23-2023 22:47
The thing is, is it Mike sync your Fitbit app to other apps, but not Apple help you have to connect to iPhone an order for your steps to be counted from your Fitbit to your iPhone I’m not sure there’s a way to do that
01-23-2023 22:47
What do you mean google fat they just made a Fitbit for Google I’m pretty sure it’s gonna go with Google Fit
Best Answer01-23-2023 22:48
01-23-2023 22:48
I just deleted that app it was doing me absolutely no good
