06-15-2024
06:22
09:39
LizzyFitbit
06-15-2024
06:22
09:39
LizzyFitbit
Date is wrong on charge 5
Best Answer06-15-2024 11:43
06-15-2024 11:43
Hello @fjtmtt
Your Charge 5 should be getting the date and time from the phone/tablet with the Fitbit app. When was the last time there was a sync between your Charge 5 & your phone/tablet?
Are you have issues with syncing any of your tracked data to the Fitbit app?
Best Answer06-15-2024 15:16 - edited 06-15-2024 15:23
Hi @fjtmtt. Welcome to the community forums.
Thank you for sharing the inquiry regarding the Charge 5.
As indicated by @RiekoC, the time and date should be automatically updated once you sync with the Fitbit app in your phone. Before considering other options, please make sure your phone meets the requirements listed here. Your Charge 5 may show an incorrect time if it hasn't synced or if it has been unpaired from your Fitbit account. Your Fitbit grabs the time of the device you're using to sync your data. If you haven't done so already, please try removing the Bluetooth connection between your phone and your Fitbit device:
Sync your Charge 5 automatically when you open the Fitbit app or manually by pressing any blank space and pull it down or tapping the upper left corner > your device tile > Sync Now. If the issue persists, please see Why won't my Fitbit device sync?
In addition, please complete a three pulse restart and let me know if you continue to experience the same problem afterwards:
Thanks @RiekoC for your help.
