06-16-2022
00:45
07:26
DavideFitbit
06-16-2022
00:45
07:26
DavideFitbit
I recently got a Charge 5. I like a clean design so I chose "target".
Usually the metrics icons are greyed out, except for the one that is selected. But now, once you toggle between different metrics, the icons don't grey out, bus disappear.
I actually returned my charge 5 because of several reasons, including this one. Yesterday my replacement arrived, but it has the exact same display issue. So I'm pretty sure that somewhere in the latest update there was a slight overlook with the target clock.
Moderator edit: format
07:25
10:46
06-18-2022
07:25
10:46
Hi, welcome to the Community forums, @Biggledigg.
Thank you for sharing your feedback about the Charge 5 device and the Target clock face.
I've been using this clock face for some time and it does seem to be the current design of this specific clock face, the icons disappear when you tap on the display to see the next stat.
In this case, I would recommend that you post this idea in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers. Make sure to post your idea including as many details as possible.
This is very helpful for the team to continue to track popularity and demand over time. Thanks again for sharing all your feedback about this.
See you around.
