08-25-2021 10:40 - last edited on 08-26-2021 15:43 by LiliyaFitbit
Does the charge 5 have an usb-c charging cable?
Best Answer08-25-2021 10:51
08-25-2021 10:51
Hi @ogaroth there isn't any information on the sales site and no user manual listed, so I'd think the charger is similar to current one. USB-C is for the end that goes into the actual device and the regular USB end that goes into a computer wouldn't make any difference. Fitbit will let us know more as they need time to get the manual up online.
08-26-2021 13:32 - edited 08-26-2021 13:34
Actually if you have a computer like mine USB-C is the end that goes into the computer and "regular" USB is a legacy connector that requires the use of a dongle. Though if you have a computer like mine you probably also have a collection of dongles for attaching legacy devices 😉.
(My money would be on it being a USB-A cable).
08-26-2021 13:50
08-26-2021 13:50
To be honest @Decoherence I wonder how much longer people will use personal computers!
08-27-2021 11:02
08-27-2021 11:02
For the Charge 5 to support a usb-c connection. I'll assume that you are asking for the Charge 5 to accept a usb-c cable.
This will not be the case, in that there is simply not enough room in the Charge 5 to add this support.
08-29-2021 05:26
08-29-2021 05:26
I can not imagine having a USB C port on the tracker. It would quickly become clogged with dirt.
09-04-2021 04:55
09-04-2021 04:55
For some of us they are far more use than a phone or tablet, though for those who basically just consume media prepared by others you have a point.
11-25-2021
05:59
11:44
EstuardoFitbit
11-25-2021
05:59
11:44
EstuardoFitbit
I have the same question. However I am asking about USB-C for the power end and the fitbit end going into the device. I have upgraded a lot of my connections to USB C, and USB A does not work in them. Is there a fitbit Charge 5 charging cable that has USB C instead of USB A?
I think they mean USB C instead of the USB A connection has comes with the Charge 5.
11-25-2021
09:20
10:33
11-25-2021
09:20
10:33
@Felix42 To clarify, the end of the cable that attaches to the Charge 5 is magnetic and attaches with those magnets to the back of the device. The power source end is USB-A. My computer has both USB-A and USB-C ports. There is no Fitbit cable that can attach to your USB-C port. I use one of the USB-A charging boxes from my phone in a wall socket.
I think many people instinctively think of USB-C as the device end, not the power source end. Fitbit caused some confusion right before the Luxe was released. Photos showed a USB-C connection to the power source. Not in real life. It’s just like every other Fitbit charging cable.
I hope this helps.
Laurie | Maryland
Best Answer11-25-2021 20:19
11-25-2021 20:19
The advantage of a USB C source is that a USB C to C cable is needed. With this, the processor in the charging source, wall wort or PC, talks with the device being charged and the C to C cable can handle 3+ times the current.
