08-02-2022
12:58
18:37
LizzyFitbit
08-02-2022
12:58
18:37
LizzyFitbit
Fitbit Charge 5, does this watch come with the charger or do you have to buy it separate?
I had one of the fitbit originals and I don't do things on a phone, so can you set them up on the computer and do they automatically update from watch to application by itself or do you have to do it manually if you don't use an I-phone?
Moderator Edit: Clarified subject and formatting
Best Answer08-16-2022 17:14
08-16-2022 17:14
Hi @Char49 the Charge 5 comes with a band and charger, but you do need a compatible phone to set up. In fact, Fitbit has informed the community that the Fitbit Connect program will no longer work in October. All of these newer devices seem to be more tied into phones.
Best Answer08-23-2022 06:39
08-23-2022 06:39
Thank You for your reply. I guess I got the answer I need, to know if I should order any of the new trackers (my old Blaze won't hold a charge anymore).
