07-20-2022
02:48
07:27
DavideFitbit
07-20-2022
02:48
07:27
DavideFitbit
My Charge 5 often starts measuring ECG and EDA without putting my fingers on either side of it. Have you also encountered this problem?
Moderator edit: format
07-20-2022
07:26
10:22
07-20-2022
07:26
10:22
Hi, welcome to the Fitbit Community forums, @Jafna.
Thank you for sharing this information about the inconvenience you've been experiencing with your Charge 5.
This is a bit odd, since your device should not be measuring ECG or EDA automatically or without you putting your fingers on the sides.
If you haven't done so already, I recommend that you try restarting the device again using the three pulse restart method mentioned here below, instead of the restart option found on the settings app of the Charge 5:
In addition, you can also try changing to a different clock face and check if you continue to experience the same behavior.
Hope this helps, I'll be around.
