02-23-2023
10:57
05:04
DavideFitbit
02-23-2023
10:57
05:04
DavideFitbit
I am not able to get the ECG to give me any results other than inconclusive. I've uninstalled the app, forced quit my phone app, restarted everything and all I get is inconclusive "the app couldn't get a good ECG reading... I'm sitting as still as possible with arms on table, I don't think my device is too loose and it is on the correct wrist as far away from electronics as possible... Does this actually work or am I just very unlucky? Tried 8 times today and no usable results...
05:04
10:34
02-24-2023
05:04
10:34
Welcome to the Fitbit Community forums, @Doxiemomkc.
I appreciate the information provided about this issue with your Charge 5.
If you haven't done so already, please try setting up your Charge 5 as a new device in your account and check if you continue to have the same problem. If the issue persists, please try the following combination of steps:
Best Answer@Doxiemomkc Please jump to page 5 of the Fitbit ECG App Physician's Guide. There is a list of reasons why users can get an inconclusive result with your additional description. One thing I would add is to touch the sensors, but don't squeeze too hard on the sensors. Squeezing too hard can create muscle motion artifact. Sadly, the last reason on the list is there are some people whose ECG signals can't be interpreted by Fitbit's algorithm. You can forward one your ECG recordings to your doctor and a set of trained eyes can review it.
Laurie | Maryland
Best AnswerHow do you even uninstall or install the ECG app on the Fitbit (Charge 5)? It was already installed when I bought my tracker two days ago. If I touch the app icon in the middle of the screen, the screen shuts off. And I don't see any install/ uninstall options for the ECG app on my paired Samsung phone. So , not sure what to do.
I've just tried now about 8 times this afternoon but keep getting "inconclusive." It was working fine yesterday. today, my heart rate is higher. Could that affect the app? Oddly, if I look at my Charge 5 main screen, it displays a recent BPM rate. But ECG app itself does not work.
Best AnswerTry moistening your finger tips before using the ECG app, if your fingers are too dry the sensor can't get a good reading.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
@rkdash Thanks for confirming that you're having this inconvenience as well.
To uninstall the app from your device, you can do it from the Fitbit app > Go to your profile > Charge 5 > Gallery > Apps > ECG app > Uninstall. Let me know if you continue to have the same inconvenience after all the steps suggested. In addition, please keep in mind that ECG feature is not available in all countries for the moment. I recommend that you review this list to check if your country has been added.
@gdio53 Thanks for sharing this recommendation!
