06-12-2023
08:07
10:28
DavideFitbit
06-12-2023
08:07
10:28
DavideFitbit
I have 2 Charge 5. One is ok while the second one not ok. When I measure my ECG the signal is jumping up and down like it is in saturation.
I restart it, cleared, it disconnect and install.
nothing help.
What to do?
thanks
Best Answer07-17-2023 07:52
07-17-2023 07:52
@Yoelr Thank you for sharing this update.
If the issue persists after all the steps mentioned earlier, you can also try completing a factory reset following the instructions listed here. Keep in mind that this procedure will remove apps, stored data, personal information, credit and debit cards* (for devices with contactless payments), and saved settings.
Let me know if you're still experiencing the same behavior after this procedure.
Best Answer06-12-2023 10:28
06-12-2023 10:28
Hi, it's good to see you visiting the community forums for the first time, @Yoelr.
I appreciate the information provided about this inconvenience with one of the Charge 5 device you have available.
If you haven't done so already, please make sure to try all the steps mentioned here below that have been helpful for other users with similar problems:
06-13-2023 14:31
06-13-2023 14:31
Best Answer06-14-2023 09:42
06-14-2023 09:42
I’m having the same problem. How does one uninstall the ECG application? Thanks.
Best Answer06-14-2023 22:07
06-14-2023 22:07
Mine just says there is an error to to open the app again, but nothing happens. Idk if I can reset the watch itself. It’s up to date, everything else works but the EKG
Best Answer06-15-2023 07:20
06-15-2023 07:20
@Yoelr @ram1946 @Isa48 Thank you for all your replies.
If you already tried all the steps suggested and you continue to have the same problem, could you please confirm if your country has been added to the list of places where the ECG feature is currently available? You can review the list here.
@ram1946 To uninstall the app, you can go to your dashboard > Profile picture > Charge 5 > Gallery > Apps > Uninstall. Let me know how it goes.
10:27
07:52
DavideFitbit
06-15-2023
10:27
07:52
DavideFitbit
Hi David
The Application appears in my phone and the tracker. My problem is that the signal is very noisy jump up and down. After 30 seconds it display that the reading failed. In my second charge 5 it works ok.
Hi
I have the application in my tracker and it functioning so it is not a country problem. It is measuring problem like the tracker can’t control the volume of the signal.
07-17-2023 07:52
