10-16-2023 16:37
10-16-2023 16:37
Nothing there when I tap to do ECG.. it says error
10-17-2023 09:58
10-17-2023 09:58
Hello @Buzz88
You might want to confirm that the ECG app is installed on your Charge 5. This help page has instructions on how to find the app and install, if needed: Fitbit ECG
If your device shows the ECG app is installed, you could try to uninstall the app, sync, then re-install the app.
Best Answer10-20-2023 23:18
10-20-2023 23:18
The app was there… it finally worked after quite a few tries
10-21-2023 03:55
10-21-2023 03:55
What if I cannot uninstall the ECG app as if I do it keeps saying "Installation failed"???
Best Answer10-21-2023 07:39
10-21-2023 07:39
Fitbit says no idea what is wrong and offer a strap instead of technical support!!!
