Hello @SunsetRunner and welcome to the Community. Sometimes my house cleaning gets get automatically sensed as aerobic workout or sport if it is a big enough time chunk of heavy duty activity. If you want to track it using the Exercise app on your Charge 5, use the Workout shortcut.
Laurie | Maryland
Hello @SunsetRunner
As @LZeeW mentioned, you can use generic "Workout" when you do housecleaning to track your activity & Active Zone Minutes. You probably want to manually start & stop the session. After you're done, you can go into the Fitbit app and rename the exercise session as "House cleaning", if you would like to keep track of it separately from your other workouts.
Hi @SunsetRunner
Your Charge 5 can currently have up to 6 workout shortcuts. From the clock face, swipe to the left to see the Exercise tile. Swipe up to see the default shortcuts.
If you want to change the shortcuts and the order:
Now, when you swipe left from the clock face to the Exercise tile, you should see the shortcuts in the order you selected.
When you're ready to start house cleaning, swipe to the Exercise tile and tap on Workout (it's the first one on my Charge 5 since I use it often), then tap Start. When you're done, tap to wake your Charge 5 (if needed), then tap on Finish.
Let us know if you have additional questions.
