08-22-2022 07:31 - edited 08-22-2022 07:31
Hi folks - I'm hoping to extend the life of my Fitbit battery--which I understand dies around 1-2 years. I wanted to run some battery longevity question by you all. Two questions:
Best Answer08-22-2022 07:50
08-22-2022 07:50
Hi, @JeffersonL great question!
I can confirm that number one point is roughly correct. I usually say keep it between 20-80%. Occasional deep discharges will not do significant harm, but having a battery charging routine of always letting it go to zero or near zero before a recharge will significantly reduce battery life. Allowing deep discharges will do much more harm than charging it above 80%.
I have never heard the second advice.
I have one Fitbit that is almost 6 years old and another that is about 4 years old and both batteries are still okay - they don’t last the full five days, but they do pretty well. How you treat your battery makes a BIG difference.
10-17-2022 18:55
10-17-2022 18:55
Hey Julia_G - quick question on your Fitbit maintenance--do you ever do a full discharge on your Fitbits periodically or do you just maintain by keeping the charge between 20% - 80%?
