11-29-2021 02:14
11-29-2021 02:14
My fitbiit 5 has been working fine but when i turn my wrist now it doesn't come on anymore and needs 2 taps to bring the screen up , any ideas to fix please ?
11-29-2021 03:13
11-29-2021 03:13
Hello @Womble73
It might be worth checking your Screen Wake setting in case it changed (some of mine did after the update). Scroll down from the Clock Face and you should eventually see a Screen Wake icon (under Water Lock), check that it's set to Auto. If it's set to Manual, you'll have to tap every time. You can just tap it change the setting.
You can also change your display settings by choosing the Settings icon and scrolling through them.
I hope that helps to fix it for you.
Best Answer11-29-2021 04:52
11-29-2021 04:52
Thats got it, thank you Wibby !!
11-29-2021 04:58
11-29-2021 04:58
I'm SO glad!
