09-04-2021
11:35
16:54
LizzyFitbit
09-04-2021
11:35
16:54
LizzyFitbit
Will Charge 5 have actual SPO2 % readings or just relative like the 3 and 4
Will there be an on demand SPO2 check available or just monitoring while sleeping.
Charge 5 specs are a little vague on this feature
thank you for your responses
Hi everyone, and welcome to our new members.
I've moved some of your posts to this thread to keep the forums organized. As you may know, the Charge 5 can track your SpO2 data during sleep in select countries. Wear your tracker securely so that the back of your device is in contact with your skin. Once you're awake, swipe up from the clock face to see your data. Make sure to sync with the Fitbit app to check your trends in the Health Metrics tile.
Please note it may take around an hour for your SpO2 values to appear after you wake up. If you haven't done so, check this help article to learn more about this feature.
Hope this helps.
Hello @Sammy16cam
Here is how to see the tracked SPO2
See your SpO2 trends in the Health Metrics tile in the Fitbit app on your phone. The Health Metrics tile is available with Fitbit Charge 4, Fitbit Charge 5, Fitbit Luxe, Fitbit Sense, Fitbit Versa 2, and Fitbit Versa 3. To see historical data, upgrade to Fitbit Premium. For other devices, a Fitbit Premium subscription is required to see health metrics data.
https://help.fitbit.com/articles/en_US/Help_article/2459.htm
In general, the Charge 5 track the SPO2 during your sleep and shows an average the next morning. If you have Premium, you can also see a graph of the SPO2 relative variation.
Hello @tyleristics
That sounds like a great idea. You could add a vote to these suggestions in the Feature Suggestions area:
Or even make one specific to the Charge 5. You could do that from here:
Feature Suggestions For Trackers
The Feature Suggestions forums are checked regularly so your vote and your voice could make a difference.
Hope this helps.
