12-11-2022 13:45 - last edited on 12-13-2022 08:59 by DavideFitbit
Failing to sync. How do I start it?
12-13-2022 08:58
12-13-2022 08:58
Hi, I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5, @Colin999.
If you haven't done so already, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
I'll be around.
12-13-2022 09:18 - last edited on 12-28-2022 10:14 by DavideFitbit
Just restarting the iPad fixed the problem. Thank you.
Moderator edit: removed personal info
12-28-2022 10:07
12-28-2022 14:55
12-28-2022 14:55
Hi, David - I have the same issue going on with my Charge 5 today. It will sync, but only 90ish% sync. It pulls over the correct battery level, my steps, my heart rate, but no sleep data, breathing rate, etc., The sync bar goes to about 90% of the way, says sync is complete, but no night data is pulled in (except oxygen rate … it did pull that in).
I followed all of the troubleshooting steps listed here and in the other articles. I also reset my iPhone, as that worked for his iPad. I reset the charge 5 using the small button, reset the charge 5 using the function on the menu, Bluetooth steps including unpairing, etc.,
The only thing I have noticed in my data is I am missing about 2 hours of bpm while I slept and it did pull over my oxygen rate.
Any ideas? Seems like it isn’t fully syncing?
01-04-2023 10:28
01-04-2023 10:28
Welcome to the Fitbit Community forums, @Cteeps.
Thank you for confirming that you're experiencing the same inconvenience with your Charge 5 and that you already tried a few troubleshooting steps.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they shared with you some instructions. In this case, they will let you know how to proceed.
See you around.
