10-07-2021 05:45
10-07-2021 05:45
Does anyone else struggle with the double tap feature on the Charge 5 after swimming? It takes me ages to unlock it to stop the workout, is there a technique I’m doing wrong? Thanks.
10-07-2021 06:29
10-07-2021 06:29
It's not only after swimming. Many times I try to wake it up by double tapping but nothing, if you flick your wrist it works...
10-07-2021 06:46
10-07-2021 06:46
Same issue here when using water lock mode, haven't found the knack yet.. if there is one.
10-07-2021 07:22
10-07-2021 07:22
I've just watched a couple of YouTube videos and it seems to work better if you take the watch off and put it on the table and firmly tap, not sure if that's helpful to either of you.
Best Answer10-07-2021 08:15
10-07-2021 08:15
The touch screen doesn't require a tap like the older, non touch screen models, I find a touch, like the touch while typing on a phones keyboard, works best.
