06-29-2023 18:16
06-29-2023 18:16
I’ve had my charge 5 for about a year and a half now and I recently got it wet at a splash pad and had been careful around water with it so this was one of the first times it’s been exposed to water. When it first got wet it didn’t turn on but after it had dried off it wouldn’t sync to my phone. After a day or two it’s now completely disconnected from my phone and will only show the Fitbit logo on it but it’s unable to connect to my phone. Any advice on how to fix this?
Best Answer06-29-2023 19:35
06-29-2023 19:35
Hi @Tyler211 -- I don't know what a spash pad is, but I managed to get my CH5 water damaged when I took it into a steam room (not recommended!). It may be permanently damaged, but there are at least two things to try. First, try restarting it using the charging cable:
If that doesn't work, try letting the battery go completely flat. That can take a while, maybe a week. Doing that partially brought mine back to life. In my case, immediately after the steam room incident I was just getting colors on the screen. But after leaving it off the charger I got it to boot up and show a normal screen. I never got it synced, but it might work for you. If it doesn't, contact support.
Scott | Baltimore MD
