01-17-2024
20:15
11:01
RodrigoMFitbit
01-17-2024
20:15
11:01
RodrigoMFitbit
After update FitBit Charge 5 won't come on and shows no charging.
Hello @aikiaka
Update to the Fitbit app would come from the Google Play or Apple app store, depending on your platform. The latest version is 4.08.
The firmware update for your Charge 5 would show up in the Fitbit app, under the device tile: Tap device icon in the upper left of the Today page and tap on the Charge 5 tile.
Best AnswerHi, @aikiaka welcome to the community, if your Charge 5 is not charging you should review How do I charge my Fitbit device? - Fitbit Help Center Note the advice about checking your USB socket is "Live" in Why isn't my Fitbit device's battery charging? - Fitbit Help Center .
Let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
@Gr4ndp4 Thanks for your advice.
@aikiaka Welcome to the forums. Thanks for reaching out about your Charge 5 not turning on.
I would like to clarify. Do you mean the latest app update or do you mean firmware update? I also recommend you take a look at the tips in the following article: Why isn't my Fitbit device's battery charging?. There are several scenarios, please give all tips a try. Thanks in advance!
Best AnswerHello @aikiaka
