10-18-2021
12:06
17:33
SilviaFitbit
10-18-2021
12:06
17:33
SilviaFitbit
My charge 5 displays only the timer. It does not show the stopwatch feature. Help.
Best AnswerWhen you get to the Timer screen, have you tried scrolling up a bit? On the first screen I have Timers, Countdown, Add. When I scroll up, I get the stopwatch with a start button.
Have a try and see if it turns up for you then.
Good luck!
Best AnswerThanks for the reply. That is the problem. It won't scroll up and show stopwatch feature.
Best AnswerI just had a quick look at the Apps gallery and the 2 come together as a set.
It might be worth uninstalling and then reinstalling the Timers App to see if it turns up. There might have been something wrong with the one that came installed with your Charge 5.
Good luck!
Best AnswerThanks for the reply I figured out how to just restart it and that did the trick. Take care!
