01-04-2022
19:49
06:01
DavideFitbit
01-04-2022
19:49
06:01
DavideFitbit
Last night no sleep recorded. Today recorded total steps but no heart rate. Also did not record my hiurly 250 steps. What gives? Software problem or faulty device. Have been using since Dec 25 and was working ok.
Moderator edit: format
Best Answer01-05-2022 06:45
01-05-2022 06:45
My heart rate stopped recording on Jan 3. No sleep record last night. What's up?
Best Answer02-28-2022 21:23
02-28-2022 21:23
Hi, did you get any help? This just happened to me on 2/28/2022. No sleep, no heart rate, total steps >10,000 but only 1 hour of movement.
Best Answer03-01-2022 00:28
03-01-2022 00:28
Mine stopped yesterday at 1230pm, same thing. I restarted as suggested, tracking steps now but heart rate monitor is reading WAY off
Best Answer03-02-2022 20:27
03-02-2022 20:27
Best Answer03-03-2022 06:00
03-03-2022 06:00
Hi everyone, and welcome to all the new users in the Fitbit Community forums.
I appreciate all the information that you've provided so far about this problem with the Charge 5. It seems that some user have mentioned the device is not tracking steps, sleep or heart rate information.
If you haven't done so already, please try a three pulse restart and check if you continue to have the same problems afterwards:
In addition, please try setting up your Charge 5 as a new device in the account if you're still having trouble. Keep in mind that there are some factors that may prevent your tracker from recording your sleep. Please make sure of the following:
Please wear your device on your non-dominant hand and monitor it for the next few days. In the meantime, for the nights that don't have sleep data, you can manually log your sleep by going to the Fitbit app, tapping on the "+" icon next to the sleep tile > Add Sleep Log and entering your details.
Regarding the problem with the heart rate as well, please follow the instructions in this article to improve the accuracy of heart rate information and check the information mentioned here about other factors that could affect your heart rate reading, this has been useful to other users who have experienced something similar.
I'll be around.
