03-25-2023 01:03
03-25-2023 01:03
FitBit is not working after only 2 months of use. Stopped working after recharging and restarting it. Still in warranty.
03-25-2023 06:23
03-25-2023 06:23
I seem to be suffering the same problem. The device just completely stopped working two days ago. The screen is absolutely blank and no amount of reboots have helps to restart the device. Please do let me know if you find a solution.
03-25-2023 06:43
03-25-2023 06:43
Same here, but it refused to pair with phone, ive done everything. Just getting the Red X of death and it drains the battery to zero, and keeps repeating this. I am starting to think there wont be any help of this, just wasted the money,
03-25-2023 08:38
03-25-2023 08:38
I suggest that you contact Fitbit support. They will walk you through a series of troubleshooting procedures. Once they confirm that none of the procedures returns your device to normal operation and if it's still under warranty, they should send you an offer to replace the tracker/pebble or a discount on a different Fitbit. If your Charge 5 is no longer under warranty, from what I've read they should send you a discount to replace your device. Note: the discount is on the full price even if the device is on sale in the Fitbit store.
This is what I had to do when the screen on my 6 month old Charge 5 became non-responsive shortly after I updated the firmware. So far, my replacement is working fine even after updating the firmware.
03-25-2023 18:29
03-25-2023 18:29
