02-07-2023 05:44
02-07-2023 05:44
Hi. My Fitbit 5 is not syncing consistently. And when it does, the sleep data disappears. I’ve logged out and in and deleted app, restarted my phone and still an issue. Worked last night, same issue as yesterday. ☹️
02-11-2023 05:46
02-11-2023 05:46
Hi, welcome to the Fitbit Community forums, @Kimmier13.
Thanks for sharing this information about the issue with your Charge 5 and all the troubleshooting steps that you already tried.
Let me know if you continue to experience the same problem to sync your data. There was an outage a few days ago affecting some Fitbit services, but this should be resolved and you should now be able to sync. You can find more information about this issue here.
Best Answer02-11-2023 17:04
02-11-2023 17:04
There appears that there is still an issue with sleep data syncing correctly. Mine hasn't since the outage of a few days ago and I have done all the troubleshooting. Reading through the other forums suggests there are many others who have done the same things and are still having issues. Id say FitBit is have issues rather than it being a wearer issue and it needs to be checked.
02-12-2023 00:49
02-12-2023 00:49
My Charge 5 isn't syncing either, the app registers the amount of charge on device, but no data synched from yesterday (Sat) or today.
02-24-2023 06:33
02-24-2023 06:33
@Daisy1972 @Tuckett31 Thanks for all the information provided so far.
It appears that some users continued to experience the same issues a few days later. Let me know if the issue persists or if it's been resolved.
If your device still isn't syncing, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
Best Answer02-24-2023 13:30
02-24-2023 13:30
I have the same issue. Syncing stops, then goes infrequently. Stopped again today. Ugh!
05:34
19:55
EstuardoFitbit
03-09-2023
05:34
19:55
EstuardoFitbit
Hi, welcome to the Fitbit Community @Jerrips.
Thanks for confirming that you've been having a similar issue with your Charge 5.
Before considering other options, could you please confirm if you already tried all the steps mentioned here earlier? Make sure to check the compatibility requirements as well.
Best Answer03-09-2023 05:43
03-09-2023 05:43
03-20-2023
10:43
19:56
EstuardoFitbit
03-20-2023
10:43
19:56
EstuardoFitbit
