10-02-2021 09:30
10-02-2021 09:30
I'm new to Fitbit and Charge 5, having liberated myself from Garmin Vivosmart 4, which measures several things incorrectly.
On successive days, I did two walks wearing the Charge 5:
* 6.91 km and 7143 steps, with calculated stride length = 97 cm.
* 6.96 km, 7106 steps, 98 cm.
This stride length is way too large for me, and for anyone else not in the NBA. Previously I had measured my stride length at 79 m.
Can anyone explain this?
Best Answer10-02-2021 10:59
10-02-2021 10:59
Fitbit sets a default stride length based on your height, etc. You can change this by tapping the Days of Exercise tile on phone app Today screen; then tap gear icon near top right. That is used to calculate distance when you are not using GPS. I don't know whether your walks distances were measured by GPS or calculated by # of steps times stride length.
10-02-2021 10:59
Best Answer10-02-2021 12:55
10-02-2021 12:55
Thanks. I was using GPS, which is why it's puzzling. I validated the distance with my vehicle.
