07-23-2022
11:30
12:13
DavideFitbit
07-23-2022
11:30
12:13
DavideFitbit
My Charge 5 is fully charged, I did do the reset by pressing 3 times on the usb cable and it did work, when plug in the battery is showing on the screen,
Underneath I can see multicolour light flashing.
on the screen I can only see 5 dots on the top and nothing else, I did try to swipe up & down and right and left and nothing happens only for those 5 dots at the top of the screen, the middle one is brighter .
12:13
04:11
07-23-2022
12:13
04:11
Hi, welcome to the Fitbit Community forums, @Manulh29
Thank you for sharing that you've been experiencing this inconvenience with the Charge 5 and that you already tried a few troubleshooting steps.
As you mentioned earlier, it's usually recommended to complete a three pulse restart on your device. Other users have also been able to resolve by changing the clock face option.
However, if you already tried these steps mentioned earlier and you continue to experience the same problem, I recommend that you get in touch with the Customer Support team for further assistance with this, or that you continue the communication with them if you already have a case created. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
07-23-2022 12:27
07-23-2022 12:27
08-06-2022 12:02
08-06-2022 19:37
08-06-2022 19:37
I tried changing the clock face. The horizontal lines went away, but the new clock face shows very washed out, for example, light gray background instead of black. Whacky.
11:19
07:02
09-01-2022
11:19
07:02
@Janet_Stephen_T Thank you for sharing that you already tried changing the clock face and that your screen seems washed out.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've provided you with more instructions. In this case, they will let you know how to proceed.
See you around.
