09-01-2022 10:43
09-01-2022 10:43
Hi, what is the point of showing the bar chart after every EDA Scan? Underneath the chart it says that “the less variations the calmer you are”. Does that mean that I should care about how many responses I had, or how much my responses varied during the session? Because sometimes I get fewer responses with more variations (for example 11 responses, in the chart: 3 1 5 2) and sometimes higher responses with no to low variations in it (21 responses, chart: 5 5 5 6) If its the amounts of responses what determines stress then whats the point of breaking it down in the chart? Does variation in the chart say something?
09-01-2022 10:37
09-01-2022 10:37
Hi, what is the point of showing the bar chart after every EDA Scan? Underneath the chart it it says that “the less variations the calmer you are”. Does that mean that I should care about how many responses I had, or how much my responses varied during the session? Because sometimes I get fewer responses with more variations (for example 11 responses, in the chart: 3 1 5 2) and sometimes higher responses with no to low variations in it (21 responses, chart: 5 5 5 6) If its the amounts of responses what determines stress then whats the point of breaking it down in the chart? Does variation in the chart say something?
09-01-2022 11:16
09-01-2022 11:16
Hi, @ericka_, welcome to the community, How do I track and manage stress with my Fitbit device? maybe of interest. There's a section on EDA scanning.
Cheers
Gr4ndp4 | UK
09-01-2022 11:22
09-01-2022 11:22
Hi, @ericka_ for the sake of good order I'm going to merge this with your other post.
Cheers
Gr4ndp4 | UK
