10-13-2023 13:19
10-13-2023 13:19
Since the latest "upgrade" my Charge 5 is not tracking my exercise on GPS. Is anybody else having similar problems and can this be fixed? Help!
Best Answer10-13-2023 16:16
10-13-2023 16:16
Welcome back to the forums @PatrickNZ .
Before considering other options, please let me know if you're using the built-in GPS or the connected GPS with your phone and if you're referring to the guidance and all the recommendations that are listed in this article.
In particular, please make sure that you've followed all the troubleshooting steps listed here below and that are also present in the article mentioned earlier:
Hold your arm parallel to your body near your head and at least 2 inches away.
If you still have trouble connecting to GPS or notice that your distance traveled seems inaccurate, try the following tips to allow your device to connect to GPS satellites:
In addition to the steps mentioned above, make sure to complete a restart procedure as well if you continue to experience the same inconvenience.
