11-08-2022 21:56
11-08-2022 21:56
Hi Team,
Facing this issue very frequently now. When I start running within 10 minutes the display pops out with GPS turned off message. GPS is turned ON in device setting as well as in Run activity also.
Thanks,
Karthik
Best Answer11-09-2022 01:58
11-09-2022 01:58
As far as I know, 10 minutes is a cut-off time for GPS trying to connect. If GPS won't connect within 10 minutes it will stop trying. The GPS turned on doesn't mean it's gets connected.
Best Answer11-09-2022 02:02
11-09-2022 02:02
Best Answer11-09-2022 02:13
11-09-2022 02:13
@Karthik_Sarma it will turn off if won't manage to connect. Do you see that GPS connected before you start running? Or it shows that it's still connecting?
Best Answer11-09-2022 02:17
11-09-2022 02:17
Best Answer11-09-2022 02:26
11-09-2022 02:26
@Karthik_Sarma I think we don't understand each other. ON doesn't mean CONNECTED. Let's retrace the steps:
- You turn the GPS on
- You start Run
- Watch tries to connect the GPS
- You should eventually see that it's connected (I don't know how Charge 5 indicates GPS status but probably by showing "Connecting" and "Connected" or some icons)
- If GPS doesn't connect within 10 minutes it gives up and turns GPS Off.
Your problem is that GPS didn't manage to connect with satellites within 10 minutes cut-off time given by Fitbit. I don't know how to explain it more simpler.
Best Answer11-09-2022 02:30
11-09-2022 02:30
