06-07-2022
07:31
06:35
DavideFitbit
06-07-2022
07:31
06:35
DavideFitbit
I got the Fitbit Charge 5 solely for the built in gps, but when ever I am running and using the Fitbit Charge 5’s built in gps, not my iPhones gps, but when I look at the stats the gps shows it is really inaccurate.
Also if I wear the Fitbit tightly, the Fitbit gps loses connection, but if I wear it loosely, the gps connects but the heart rate is inaccurate.
please fix.
06:34
08:00
06-17-2022
06:34
08:00
Hi, thank you for sharing this information about the problem you've been experiencing with your Charge 5, @ShadowNinja.
If the GPS is getting disconnected during your activity, the Charge 5 may track different information for the the distance. If you haven't done so already, please make sure to follow the steps suggested in this article to improve GPS accuracy.
Keep in mind that all devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time. In particular, please make sure of the following:
If you continue to experience the same behavior and your GPS is getting disconnected, make sure to try following the steps listed in this article to complete a three pulse restart using the charging cable, as this has been useful for other users experiencing something similar.
Best Answer06-09-2023 07:20
06-09-2023 07:20
I was using GPS Dynamic setting on my Fitbit Charge 5. Yesterday, I switched it to GPS Phone and it was accurate. I also use MapMyRun at the same time. I was ready to toss my Fitbit in the trash up until yesterday. The suggestion by Fitbit to wear it loose to improve GPS, no trees, etc, just really bothered me. Especially when they say for more accurate Heart Rate you should have it snug/firm. Basically saying if you have to choose between accurate GPS or more accurate Heart Rate monitoring. When I bought my device, I didn't know I was paying for an either or situation.
07-12-2023 05:38
07-12-2023 05:38
@KevinDuganJr Thanks for taking the time to share your feedback and your experience with this. It's good to know the connected GPS feature is working for you.
The team continues to work to improve the quality of products and your feedback is an important part of that process.
Best Answer07-12-2023 05:41
07-12-2023 05:41
lol great timing for you to reply to my message because my Fitbit Charge 5 died yesterday. Screen had flickered for few days, went solid white/yellow, but still tracked sleep, steps, etc -- until yesterday. I think that might be my last Fitbit. We'll see though!
08-17-2023 12:38 - edited 08-17-2023 12:40
@KevinDuganJr Thank you for your feedback and for your reply confirming that your screen is now unresponsive.
If you already tried to complete the 3 pulse restart procedure and you continue to experience the same problem, please try these additional steps that have been useful for other users:
Best Answer08-23-2023 05:15
08-23-2023 05:15
Thank you, but it's destroyed. I tried to heat up the face and pull the screen off to replace it. I over heated it though. Whoopsie! 😁 If I were to try and fix it, I would have to replace the screen that I "burnt" and it's not really worth the $30 plus time/effort to fix.
Best Answer09-19-2023 08:38 - edited 09-19-2023 08:39
@KevinDuganJr Thanks for the update.
I'm sorry to see the device is destroyed, please know that all your feedback about the product is really appreciated.
09-19-2023 08:45
09-19-2023 08:45
You're welcome. It was a nice little device at times.
Best Answer09-24-2023 08:47
09-24-2023 08:47
@KevinDuganJr No problem!
