02-02-2024 10:17
02-02-2024 10:17
Did Fitbit eliminate the tracking of night-time breathing fluctuations? All of a sudden, I no longer have this graph in the sleep tab for my Fitbit Charge 5. If it was not globally eliminated, any suggestions on how to correct the problem? Many thanks!
Best Answer02-02-2024 12:18
02-02-2024 12:18
Hello @Mbear01
I think you're asking about the Estimated Oxygen Variation under the Restoration. I see the graph in my sleep log details.
I know there are some sleep data that's only available with a Premium subscription. However, I didn't see Estimated Oxygen Variation as one of the Premium features. So I think you should see it without a Premium subscription.
Is there any other sleep data you're not seeing?
Best Answer02-03-2024 09:13
02-03-2024 09:13
You're correct, I no longer see the graph in my sleep log details. Everything else seems to be working fine, so that's why it's so puzzling.
Best Answer02-04-2024 12:00
02-04-2024 12:00
Hi @Mbear01
Thanks for confirming which graph you're not seeing.
I'm not sure why you aren't seeing this graph in your Fitbit app, especially since you're having problems with any other data. One thing that might be worth trying is doing a force stop and clearing the cache for the Fitbit app in your phone.
