09-18-2025 23:08
09-18-2025 23:08
Holter 72 hour ECG reported a 7-beat run average rate of 150 bpm.
Compare this finding with Fitbit Data file of heart-rate. A heart rate of 150+ for 6 samples (at 5 seconds samples) hence 30 seconds of sustained 150+ heart rate. This can also be stated in heart beats. 5 second sample at 150 bpm corresponds to approx. 12.5 beats between samples. So the 150+ heart rate occurred for 75 heart beats.
Holter (considered the gold standard) suggests the Fitbit data is completely wrong and maybe misleading.
Anyone else seeing similar findings??
Best Answer09-19-2025 06:25
09-19-2025 06:25
Hi @Jeff_Holter_ECG Every Fitbit will be different from a Holter ECG. An ECG tracks electrical impulses in the heart. An optical heart rate monitor (OHRM) looks for pulsations in tiny blood vessels under the skin. There are many reasons why an OHRM will be different from an ECG. A Holter is a medical grade ECG. Fitbit says that its OHRM data is for health and fitness goals and are not designed as scientific or medical purposes.
Laurie | Maryland
09-19-2025 15:30
09-19-2025 15:30
Best Answer09-20-2025 05:45 - edited 09-20-2025 12:44
@Jeff_Holter_ECG Your images didn't come through. I can't tell what point you are trying to make.
I hope this explanation makes sense. A Holter monitor will count every heart beat. The heart fills with blood in between two heart beats. When two (or more) heart beats come close to each other, not enough blood gets pumped out to create a pulsation at your wrist.
Laurie | Maryland
09-20-2025 16:17
09-20-2025 16:17
Best Answer09-22-2025 21:47
09-22-2025 21:47
So I purchase a Polar H10 Heart rate sensor and went for a 64 minute walk. Fitbit recorded avg heart rate of 106 bpm with max of 158 bpm with heart rate above 130 bpm for 3 minute.
Compare this with The Holter H10 report - avg heart rate 87 bpm, max heart rate 101 bpm. Zone readings show 0% in zone5 (130 bpm & above), 0% in zone 4 (115 to 130 bpm), 1% in zone 3 (101 to 115 bpm), 59% in zone 2 (86 to 101 bpm) and 40% in zone 1 (72 to 86 bpm).
I will continue the comparison for a few months, but it seems my fitbit is way out.
Good news for the condition of my heart.
The Holter H10 uses electrical signal like an ECG, not as good but by all accounts between that all watches.
