12-18-2021 13:35
12-18-2021 13:35
I have no use for the Water Lock and it keeps interrupting my runs and workouts when it senses water. How do I disable that all together? As a participant of Spartan and ToughMudder events, every time an obstacle has water the watch stops tracking my race GPS and time. Need that option Out altogether from the watch. What can I do?
Best Answer12-18-2021 14:18
12-18-2021 14:18
I think you can just turn it off. I just purchased my Charge today and the Water Lock feature is completely off. Maybe just go to that and turn it off? All I did was scroll down and it shows it off. But I turned it on and it advised me to double tap and it turned off. Hope this helps.
Best Answer12-18-2021 15:19
12-18-2021 15:19
Hello @UNALTERED
It sounds like it might be faulty. It should only turn on when you actively tap to turn it on or when you set Swim as an activity. If you're not doing either of those things, there's probably a problem and you should contact Support.
Here's a link to support for the UK. Scroll down to the bottom of the page to change the country if you need to.
I have also heard that using the Chat version is the most effective.
Good luck and let us know how you get on.
