06-18-2023
23:42
08:16
06-18-2023
23:42
08:16
How do I change clock faces on Charge 5?
Best Answer06-19-2023 02:51
06-19-2023 02:51
Hi, @Dvorah, welcome, in the Fitbit app on your phone do the following. From the "Today" screen touch your icon in the top left corner>Charge 5 tile>Gallery> Clocks tab>to see 25 clock faces, your current clock face will have a checkmark under it. Touch the clock face you want and look at the description, if it's what you want > Install> See the red progress bar in the app & green progress bar on your device> On completion the new face will be present on your Charge 5. Return to the today screen in the app. You can change the faces as often as you like, do pay attention to the "Description" as many have different characteristics & data displays.
I hope this helps.
Cheers
Gr4ndp4 | UK
06-19-2023 02:51
06-19-2023 02:51
I hope this helps.
Cheers
Gr4ndp4 | UK
