04-07-2022
08:18
19:59
LizzyFitbit
04-07-2022
08:18
19:59
LizzyFitbit
I’ve got the blue hook and loop band for my charge 5, and I love it. It’s starting to look a little dingy, and I’m wondering if anyone has washed theirs. Did you do it by hand? In the washer? What did you use?
07:38
10:32
04-24-2022
07:38
10:32
@Jencads Fitbit doesn’t really address cleaning that band. I don’t own that band, but have owned other Fitbit woven fabric bands. I took them off the pebble and washed them by hand with Woolite (a detergent for delicate fabrics, in case you aren’t in the US). I let them air dry.
Fitbit must call this a hook and loop band, because they aren’t using Velcro, the brand name. I have used Woolite on other hook and loop items and it didn’t harm them.
Laurie | Maryland
@Jencads Welcome to the Community Forums.
I'm glad you got a Charge 5 with a hook and loop band. In regards to your question, please be sure to follow our Wear and Care instructions to keep your device and wristband clean. I hope you can keep crushing your goals with your tracker! 😊
The cleaning instructions say to use cetaphil, which is not an appropriate cleanser for fabric. Are there more appropriate instructions for these fabric bands?
07:38
10:32
04-24-2022
07:38
10:32
Laurie | Maryland
