05-21-2022
14:16
05:33
05-21-2022
14:16
05:33
Hi,
How can I replace my old fitbit by fitbit charge 5. should I cancel my existing account ?
Thanks in advance for your answer
Best Answer05-21-2022 15:20
05-21-2022 15:20
Hi @SunsetRunner first sync your Charge 2 one last time and get it out of range while you set up the new Charge 5 as a new device on an existing account. You can always remove the Charge 2 from your account before adding the Charge 5, but usually it will ask if you want to replace it. If you don't want to start your stats from zero, then just keep using the same account. Your history will be there and you can keep on your journey.
05-29-2022 13:00
05-29-2022 13:00
Best Answer05-29-2022 13:17
05-29-2022 13:17
@SunsetRunner then it's easier to use your old account to set up the new device.
