01-12-2023
23:57
12:50
LizzyFitbit
01-12-2023
23:57
12:50
LizzyFitbit
Add cycling to the exercise options
01-24-2023
14:27
04:03
01-24-2023
14:27
04:03
Hi there, @SamSpoons.
Thanks for getting back with more details. Let me explain the screen you're seeing is called Mobile Run which allows you to track certain activities directly on the Fitbit app. On the other hand, your Charge 5 has the Exercise app which includes around 20 exercises to choose from.
To track an exercise using your tracker, please follow these steps:
On your Charge 5, swipe right or left to the Exercise app, and swipe up to find an exercise.
01-16-2023
14:57
04:03
01-16-2023
14:57
04:03
Hi @SamSpoons, and welcome to the forums.
Thank you for sharing your Feature Suggestion with the Fitbit Community. Let me share the Exercise app already has Bike as an option to track this activity on your Fitbit device. For more information, see this help article.
If you're referring to something different, please reply with more detail or specifics on how this idea would work, or what problem this is trying to solve as this will help us to better understand this request. We look forward to your response.
01-16-2023 15:34
01-16-2023 15:34
01-22-2023
12:55
04:03
01-22-2023
12:55
04:03
I've moved your posts to the Charge 5 board as it seems this is more a question and not a feature request. Thanks for reviewing the information mentioned before. Our Fitbit devices have a variety of exercises available and the help article shared above will provide you with instructions to use the Exercise app. Once you open this app, scroll down and tap the exercise of your choice (Bike). Then tap the play icon so you can track your activity.
01-23-2023 06:37
01-23-2023 06:37
I open the Fitbit app and press the + under Track your exercise.
I then get a local map with Walk at the top which I tap on to see the options - this leads me to the following screen
Exercise Type
Run
Walk
Hike
Run, Walk or Hike but no Bike option.
thanks. Ian
01-24-2023
14:27
04:03
01-24-2023
14:27
04:03
01-24-2023 15:00
01-24-2023 15:00
01-25-2023
10:25
04:05
01-25-2023
10:25
04:05
@SamSpoons It's good to see you again.
You're welcome! Thanks to you for keeping me posted, I'm glad the instructions provided above were of help. I'm going to mark my post as the Best Answer in order to help other members with similar questions.
By the way, check out our Health & Wellness board where you can make new friends, create topics and find encouragement from other members!
