04-22-2022 02:02
04-22-2022 02:02
When I am out, the charge 5 vibrates - how do I turn the screen on to see what the message is?
is there a display setting to automatically turn display on when there is a notification?
(I must say, I have never met a gadget with less clear instructions!!!)
04-22-2022 03:24
04-22-2022 03:24
Swipe to the left on your display and it should say notifications or just lift your wrist 😊
04-22-2022 05:14
04-22-2022 05:14
Best Answer04-22-2022 06:03
04-22-2022 06:03
Hello @fatandflabby
You can set the display to Auto and it should turn on when you turn your wrist (or raise it).
From the main clock face screen, scroll down and you should come to Screen Wake, tap it to set it to Auto. Also make sure that DND and Sleep Mode are set to Off.
I hope that helps.
04-22-2022 07:04
04-22-2022 07:04
