07-06-2023
00:53
10:30
ManuFitbit
07-06-2023
00:53
10:30
ManuFitbit
Please can you advise me on how to track a misplaced charge 5
Moderator edit: clarified subject.
Best AnswerHi, @Nishka20 , if your Fitbit still has some charge you can go to places where it might be and see if it syncs (either spontaneously or by using “sync now” in your app). If it syncs then it is nearby.
There are also a couple of blue tooth finders you can use, depending on which phone operating system you use. More info is here .
If your Fitbit battery is dead, I am afraid it is a matter of detection and search - try to think where you last had it or where it could have fallen off…. One top tip is to check your laundry basket - that seems to be where many users find a lost fitbit - or amongst the bedclothes, if it could have come off in the night.
