01-31-2023
07:25
05:34
DavideFitbit
01-31-2023
07:25
05:34
DavideFitbit
I recently got a Fitbit Charge 5, and am really liking it. The only major struggle I'm having is how to get my calendar notifications on the Charge 5, though. I use an Android phone (Pixel 7 Pro) and the built in Google Calendar app.
In the Fitbit app on my phone, I have enabled the "Calendar Events" notification and selected the Google Calendar option. However, no calendar notifications show up on my device, which is a little frustrating.
Does anyone have any advice on how to get my calendar items to appear on the Fitbit Charge 5? Thanks so much!
02-14-2023 05:32 - edited 02-14-2023 05:33
Hi, I appreciate all the information provided and the details about this issue with your Charge 5, @ischustak.
Let me know if you're having trouble to receive any other notifications of if this is only happening with the calendar notifications. The settings you mentioned earlier to turn on Calendar notifications in the app settings should work. If you haven't done so already, please try turning the notifications off completely and set them up again.
If the issue persists, you can also try setting up your Charge 5 as a new device in your account. In addition, make sure that you have the latest version of the Fitbit app installed and to check all the compatibility requirements here. Keep in mind that you won’t see notifications on your Fitbit device if you turned on the Do Not disturb Icon or Sleep Mode.
