07-06-2022
05:18
06:26
DavideFitbit
07-06-2022
05:18
06:26
DavideFitbit
How do you remove small band?
06:25
08:39
07-06-2022
06:25
08:39
Hi, welcome to the Fitbit Community forums, @Retired-NYC2002.
Thank you for sharing your inquiry about the Charge 5 and the wristband.
The procedure to remove both of the bands should be the same. Your device has 2 detachable bands (top and bottom) and to switch between small and large bands, you only need to replace the bottom band. To remove and replace a band:
Hope this helps, I'll be around.
