04-18-2022
19:38
07:00
DavideFitbit
04-18-2022
19:38
07:00
DavideFitbit
How do I set this up to take a ecg?
Hi, welcome to the Fitbit Community forums, @Vcog.
Thank you for sharing your inquiry about your Charge 5 and the ECG app.
You can find the Fitbit ECG app on your Fitbit wrist-worn product by swiping left on the screen. You can also find the the Heart Rhythm Assessment section within the Health Assessments & Reports section in the Fitbit app on your phone or tablet. If you don’t have the Fitbit ECG app installed, see How do I install the Fitbit ECG app?
Note that the Fitbit ECG app is only available in select locations at this time since this feature often requires the approval of certain agencies and institutions of each country before they can be activated for use. I recommend that you review this list periodically to check if your country has been added.
Hope this helps, I'll be around.
